Whirlpool Galaxy
  • Member since
    March, 2009
Whirlpool Galaxy
Posted by DarylGS on Sunday, April 05, 2009 4:21 PM
Just wondering if anyone has viewed the Whirlpool galaxy usning an 8" SCT or would a larger apeture be necessary?
Moderator
  • Member since
    July, 2001
Posted by DaveMitsky on Sunday, April 05, 2009 5:45 PM
M51 is visible through a 7x35mm binocular from a good dark site.  I've observed it many times using 80 and 101mm refractors, as well as far larger apertures.
You should be able to see M51 and NGC 5194 and perhaps even a hint of M51's spiral arms through your 8" SCT, depending upon conditions and your observing skills.
http://www.clarkvision.com/visastro/m51-apert/index.html
Dave Mitsky
Sic itur ad astra!
  • Member since
    March, 2009
Posted by DarylGS on Sunday, April 05, 2009 5:51 PM
Thanks.  I thought it unusual that I saw nothing.  Long story short, it is a relatively new scope.  I used the GoTo and it pointed me into a part of the night sky that had nothing (visually speaking) in it.  I tested the GoTo on a couple of other objects and they came up dead center.  I just had to be sure that I"M not going crazy.  OK, maybe the night sky conditions weren't good for very deep DSO's?
  • Member since
    March, 2009
Posted by catzal on Sunday, April 05, 2009 5:56 PM
M-51 looks beautiful in 20X80 binoculars from a dark site and M-51 and NGC 5194 are easily visible in a 6 inch scope even under lousy skies.  Just don't expect much detail.  For a large galaxy like M-51 dark skies make an incredible difference in what you can see.
Qui scribit bis legit.
  • Member since
    March, 2009
Posted by DarylGS on Sunday, April 05, 2009 6:03 PM
Then I'll have to give it another try in another area.  Unfortunately, I live in an area of the state that suffers from the worst light pollution.  As "dark" as I thought the area around me was, obviously I'll have to find darker.
 Thanks
Moderator
  • Member since
    July, 2001
Posted by DaveMitsky on Sunday, April 05, 2009 6:10 PM
What magnification(s) did you use?  Many people buy into the myth that low power should be used on deep-sky objects.
Dave Mitsky
Sic itur ad astra!
  • Member since
    January, 2004
Posted by tkerr on Sunday, April 05, 2009 6:14 PM
First make sure you're finderscope is aligned with your telescope. Then when do your star alignment, if you haven't got a reticle EP use a short focal length EP for more acuracy. Then when you choose the object for your mount to move to, start with a longer focal length eyepiece. Your using a long focal length SCT so you will want to start with no less than a 25mm EP.
Allow your eye to adjust to the view through the EP using averted vision.  You should be able to see the faint butvery recognizeable shape of the Whirlpool and its companion. Then step it up from there. It should look pretty good with a 8" SCT as long as your skies are dark.
Have A Nice ...
Find me on Google Plus
Equipment: Orion XT10 Classic, Celestron C6 R-GT (CG5 GT mount), C80ED Canon EOS 350D, Canon EOS 50D, Meade DSI II Color CCD, Phillips SPC900NC
  • Member since
    March, 2009
Posted by DarylGS on Sunday, April 05, 2009 6:38 PM
I started off with a 32mm 2" eyepiece.  I could go to 25mm, but as I said, there was nothing there.  My finderscope is aligned almost perfectly and all objects show up dead center in the finderscope and the tube. It was just bizarre because all other objects that I punched in came in just fine.
  • Member since
    March, 2009
Posted by catzal on Sunday, April 05, 2009 6:47 PM
Also rememeber that 51 is huge, much larger than many other galaxies so the light is spread out and the contrast is poor.  Move the scope around and use averted vision.  You might just see a slight glow in the darker background until you get used to it.  M-101 is also like this and in polluted skies 101 can be a difficult galaxy to find even though it is quite bright.
 Also I agree with Dave that higher powers help greatly on many galaxies, increasing the contrast with the background.  Just rememeber that with higher power you probably won't see the entire galaxy in your field on view.  However, there really is no subsituted for dark skies when looking for detail in large galaxies.
  • Member since
    March, 2009
Posted by DarylGS on Sunday, April 05, 2009 7:05 PM
Thanks, all for your insight.  I'm going out tonight into a much darker area and we'll see what happens.  I'll keep the size of the object and the FOV closely in mind.
  • Member since
    March, 2009
Posted by catzal on Sunday, April 05, 2009 7:06 PM
Just another thought on large galaxies.  When I lived in New Mexico I could frequently see M-33 with the naked eye.  But even under those conditions I always though it looked far more pleasing with a 8X50 finder or large binoculars than with my 13 inch scope.  it was just too dang big.
Moderator
  • Member since
    July, 2001
Posted by DaveMitsky on Monday, April 06, 2009 12:20 AM
M51 is 11 x 7 arc minutes in apparent size, which I would not characterize as huge, although it is larger than most.  (For the sake of comparison, M33 subtends 73 x 45 arc minutes.)
M51 is fairly bright, having an integrated magnitude of 8.4 and a rather healthy surface brightness of 12.6 magnitudes per square arc minute.  The face-on galaxies M33, M74, and M101 are far more difficult to see from less than dark sites, since they have low surface brightnesses of 14.2, 14.4, and 14.8 magnitudes per square arc minute respectively.
Dave Mitsky
Sic itur ad astra!
  • Member since
    February, 2008
Posted by WABarry on Thursday, April 09, 2009 3:08 AM
From a driveway or backyard, assuming some light polution, it is a difficult target.   You should see two fuzzy "stars" (the brighter centers of the of the two objects), M51 and it's smaller companion.  From a dark sky, away from city lights, you should see some evidence of the spiral structure....a glow around one of the fuzzy "stars".
10 inch classic Dobsonian, Orion 150mm f/5 imaging Newtonian,  Celestron Nexstar 4se OTA,  Orion 80mm short tube refractor,  Celestron CG5 GoTo mount,  Canon 350D DSLR (unmodified),  ToUcam pro II 840k,  Orion Starshoot II color,  Orion 9x63 binoculars
  • Member since
    May, 2008
Posted by StarNerd on Thursday, April 09, 2009 9:45 AM
Hi everyone,
I viewed M51 a few weeks ago for the first time.  I have light-polluted skies - limiting magnitude at zenith at the time I viewed the galaxies was about 4.5.  Using the Zhumell Z12 12" scope and a 9.7mm plossl EP, I could only see the bright cores of both galaxies, but no structure.  I made the following sketch:
Last year I recall searching many times for M51 and not finding it.  I was using a 5" reflector at the time.
Note that I am fortunate to have a very dark observing spot despite the sky glow (very little light intrusion from neighbors).  This allows my eyes to get as dark adapted as possible.
Zhumell Z12 12" F/4.9 Dob with Telrad+8X50 RACI Finder Home-built 5" F/5 on a DS-2000 Go-To Mount with Red Dot Finder Baader Hyperion Eyepieces (24mm, 21mm, 17mm, 13mm, 8mm, 5mm, 3.5mm) Baader Hyperion Aspheric Eyepieces (36mm, 31mm) 16x50 Bushnell Binoculars
  • Member since
    February, 2009
Posted by Orionis2009 on Tuesday, May 12, 2009 8:38 PM
 A few weeks ago, i saw m51 through my 5 inch relfector using the 32mm possl eyepiece under the extremely light polluted skies of SLC. the galaxy was very very, and i mean VERY faint, and i had to "shake" the telescope a bit to even detect it.
Zhumell Z12 Deluxe Reflector Celestron 127EQ Reflector Bushnell 10x50 Binos Salt Lake City Skies Knolls Skies
  • Member since
    January, 2004
Posted by tkerr on Wednesday, May 13, 2009 11:44 AM
Orionis2009
 A few weeks ago, i saw m52 through my 5 inch relfector using the 32mm possl eyepiece under the extremely light polluted skies of SLC. the galaxy was very very, and i mean VERY faint, and i had to "shake" the telescope a bit to even detect it.
You mean M51?
M52 is an open cluster in Cassiopeia
Have A Nice ...
  • Member since
    February, 2009
Posted by Orionis2009 on Wednesday, May 13, 2009 9:05 PM
 yeah m51 (whirlpool galaxy)....sorry for the typo
  • Member since
    May, 2009
Posted by Vlad1980 on Monday, May 18, 2009 12:54 AM
 I am new to all of this but I tried to find it on my scope few days ago and no luck. I guess I have to learn star hopping little more to find it. For example, I spotted Ring nebula fairly quickly, but this one got away from me... for now.  I used 38mm (2") and 25 EPs.
Edit: I think I just realized that I was actually looking to find M101, not M51. Both are in Ursa Major.
Orion XT8 Classic Dobsonian 38, 25, 7-21mm eyepieces 9mm Expanse eyepiece 3 and 2 x Barlow Lens 15 x 70 Celestron binocs Canon T1i for some wide shots
  • Member since
    January, 2004
Posted by tkerr on Monday, May 18, 2009 9:16 AM
Vlad1980
Actually M51 is in the Canes Venatici Constellation
There is a asterism of 3 stars forming a triangle near the vicinity of M51, if you can find that you will have no problem finding M51 provided you have clear dark skies. Although it can be found using low magnifications under dark skies, that is one galaxy that benefits from higher magnification and averted vision.
Have A Nice ...
  • Member since
    May, 2009
Posted by Vlad1980 on Monday, May 18, 2009 9:26 AM
 Thanks!
Next clear night I will try to look for it as well as M51.
  • Member since
    May, 2008
Posted by StarNerd on Monday, May 18, 2009 9:48 AM
Hi Vlad1980!
I have found that M101 (Pinwheel galaxy) was one of the most difficult galaxies I've detected so far.  I'm from central NJ too and the light pollution makes low surface brightness galaxies extremely difficult to see.  Disapprove  I was just barely able to detect M101 as a wisp of haze with averted vision on a night of good transparency.  And, I'm using 12" of aperature.
I think you actually have a better shot at seeing M51 as it has a higher surface brightness.
M101 is above (North) Alkaid.  It makes an almost equilateral triangle with Alkaid and Mizar/Alcor such that M101 is at the tip of the triangle above (North) the dipper's handle.
If you look at Alkaid then look South West by about 10 deg., the next bright star you'll come across is Cor Caroli in Canes Venatici.  M51 lies roughly on this line about 1/3 of the way from Alkaid to Cor Caroli.  Incidentally, M63 (Sunflower galaxy) also lies roughly on this line about 2/3 of the way from Alkaid to Cor Caroli.  M63 is a tough one as well, but not as tough as M101, IMO. Smile
M94 is an easier galaxy to see and it lies North of the line adjoining Cor Caroli and Chara.  They make a wide obtuse triangle with M94 at the wide tip.
Last year, while searching this area with my 5" reflector, M94 was the only galaxy I could see.  Disapprove  I was not able to find the others (M63, M51, and M101) until this year when I used the 12" reflector.
Moderator
  • Member since
    July, 2001
Posted by DaveMitsky on Monday, May 18, 2009 11:42 AM
Sic itur ad astra!
  • Member since
    February, 2009
Posted by Orionis2009 on Monday, May 18, 2009 10:46 PM
 update:
this past weekend i went to a semi-dark area (about 20 minute drive from my house)  and observed m51 through my 5 inch reflector. i had no trouble finding the galaxy, but it was still very faint even though i resolved both m51 and its companion (two smudges near one another(
  • Member since
    May, 2009
Posted by Vlad1980 on Saturday, June 27, 2009 6:51 AM
Thanks for the tips... I was able to observe M51 (and its companion) and M101 in my scope on my trip to upstate NY .. unfortunately, I had bigger plans as far as number of DSOs to see, but unexpectedly cold nights and my drunken friends made it a little hard to accomplish. But, still I am very happy with my progress overall.
Join our Community!
Loading...
